K&N air filter
Old Jan 14, 2007 | 10:14 PM
MaxKid84's Avatar
Default K&N air filter
I found one on ebay for about $63 shipped.
Should I look else where?
is it really worth it for the performance?
Old Jan 15, 2007 | 05:52 PM
Tahoe SC's Avatar
Default RE: K&N air filter
there's really no performance...it doesn't flow better than stock.
Old Jan 15, 2007 | 06:22 PM
Grady's Avatar
Yeah, dont worry bout that unless your getting a slip on and a PCIII.
Old Jan 15, 2007 | 09:05 PM
MaxKid84's Avatar
I've got a yoshi can, I don't think its a full system.
and I'm installing a K&N jet kit, stage 1 & 2.
would the K&N really help the jet kit that much more. I'm just hurtin for cash but I want to get the most out of the bike that I can, it'll be tuned once everythings done.
Old Jan 16, 2007 | 02:15 AM
big10donjuan's Avatar
did someone say a slip on and a PCIII on an F1??? are you serious??
meither way... I got a K+N when I had my jet kit installed... There is a definate boost in the power but the bike hesitates/ bogs right about 6K rpm ... it's fine if you are aggressive with the gas but if you try and gently gas it from 5500-6500 it stumbles for a second. I'm probably going to have to go over the carbs in the spring......
does anybody know if an ignition advancer will help this??
Old Jan 17, 2007 | 08:31 PM
michigan_313's Avatar
ignition advancer will help on the bottom end and power spread at cruising speeds. kit usually runs $50. advance is +4 and may require a little bit of retuning.
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
