hurricane 600 help !
Old Mar 28, 2014 | 03:23 PM
cbr6001988's Avatar
New Member
Default hurricane 600 help !
Does nayone know the correct firing order for the cane my ht leads r numbered 1 to 4 an can't remember which went were thanks in advance
Old Mar 28, 2014 | 07:37 PM
CorruptFile's Avatar
June 2013 ROTM
Cylinders are 1-4, left to right (looking from back to front)
Old Mar 29, 2014 | 02:41 PM
cbr6001988's Avatar
New Member
Default hurricane
Thanks I have 1 other issue the start button won't turn the engine over the switch has been checked an is ok an the contacts are all clean an the fuses r good to any idea what it could be
Old Mar 29, 2014 | 05:26 PM
June 2013 ROTM
Is the bike in neutral? Try pulling the clutch. Not sure if it needs to be pulled on the f1's, I've got a bridged clutch switch
Old Mar 29, 2014 | 09:49 PM
MrGiggles's Avatar
There is a clutch switch although mine doesn't seem to be functional. I don't think they would have put the switch on the bikes if it didn't do anything.
Get a wiring diagram of the starting system from the manual in the sticky section of this forum. Starting tracing the path to the starter solenoid.
Does the neutral light work? Mine has to be in neutral to start.
Old Mar 30, 2014 | 02:59 AM
cbr6001988's Avatar
New Member
Default thanks
Thanks ill try it with clutch pulled in it hasn't got a chain on it so iv been turning it over by bridgeing the terminals on the solanoid but ill try what u said thanks again
Old Mar 30, 2014 | 06:41 AM
cbr6001988's Avatar
New Member
Default thanks
Thanks for your help guys she's startin an running great jus need to get an end can an chain an she'll b back on the road
Old Mar 30, 2014 | 10:21 AM
cbr6001988's Avatar
New Member
Default problem
I sat on the bike an copied the diagram u sent me so I started from the left cyclinder 3241 I started the bike ran ok but when revved as the revs come down it sort of stops on 2000 then goes back to 1400 ?? Sorry to be a pain all the help is appreciated I'm still learning lol
hurricanematt
Aug 9, 2019 12:21 PM
cal_look_zero
Jun 15, 2012 09:34 AM
Saldo1981
Jan 2, 2009 08:43 PM
ebinz88cane
Apr 25, 2008 06:05 PM
BostonCBR600
Mar 15, 2007 10:44 PM
