Hung up float?
Old Jun 24, 2009 | 02:17 PM
MrHorsepower's Avatar
Default Hung up float?
Hi all,
Just spent time cleaning and jetting the carbs along with new needles. After I tested the carbs for leaks on my bench I had to change the float bowl gaskets and the oring to all the fuel lines. Tested again, through use of gravity and all was good to go.
Put it all together and fired the bike up and it was fine for about 30 seconds then started pouring a full stream of gas out of carbs 1&2 overflow. I tapped the carbs hoping it was the float while it was running but to no avail.
As soon has I tipped the bike to level it shut off. I had to choke it to fire it and was adjusting the idle to 1000 rpm when it started.
I am in the process of buying a carb sync, how do I carb sync this? I read the write up on the 1000, but the 600 does not have the same vacuum ports.
Thanks,
Bob
Old Jun 24, 2009 | 07:38 PM
tds94probe's Avatar
i believe you adjust cbetween carb 3 and 4 first then between 3 and 2, then between 2 and 1.
Old Jun 24, 2009 | 07:42 PM
Thanks for the info, but where do you hook up the vacuum lines for the guages/sync?
Old Jun 25, 2009 | 12:26 AM
KongBastard's Avatar
There are vacuum ports on the head, just below where the carbs enter the head.
Download a manual. Make your life easier.
KongBastard
Old Jun 25, 2009 | 01:21 AM
Gogar's Avatar
About your overflow problem:
You need to take the 1 and 2 floats out of the assembly. Get a little bowl and fill it with gasoline. Toss each float in that bowl of gas and see if it . . . . . floats.
Sometimes floats can get a little crack in them and they don't float anymore, which keeps them at the bottom of the float bowl, and gas keeps flowing in the carb because the needle won't rise to shut the gas off.
Good luck!
Old Jun 25, 2009 | 01:24 AM
Gogar's Avatar
About the vacuum ports:
There's a little 5mm cheeze-head phillips screw right on the HEAD, not the carbs. It's right past where the rubber manifolds meet the head. Unscrew that screw and insert the fittings that come with your sync kit into those holes.
To sync, you need to have the tank and (I think, can't remember) the airbox off. There's 3 phillips screws, one in between each of the 4 carbs, that you can adjust to get all 4 even with each other.
Old Jun 25, 2009 | 06:58 AM
Thanks for the replies. I am tearing it back down again.
Old Jun 25, 2009 | 07:34 AM
Haskell76's Avatar
Manual on Ebay right now for 9.99. I got mine there.
Old Jun 25, 2009 | 05:18 PM
tds94probe's Avatar
I assume that your little CAPITAL word was directed at me, and I never once said that the vaccum connections were in the carbs, simply explaining which order to sync them in, which was in fact his question.
Old Jun 25, 2009 | 06:00 PM
Gogar's Avatar
Wasn't even thinking about you, sorry. Your post and mine are talking about different things. I put HEAD in capitals because the first time I went to sync my carbs I stared at the carb bodies for about half an hour trying to figure out where to put the vacuum fittings that came with the kit.
Switch to decaf? Have a good day!
jarvid
The Hurricane Saloon
Jan 3, 2015 03:52 PM
WARDEN26
F2 Tech
Jul 31, 2010 08:10 PM
gator215
Apr 10, 2010 08:00 AM
ebinz88cane
Mar 1, 2010 02:01 AM
furious82
May 18, 2005 08:32 AM
