How to connect a koso rev counter on a 600 hurricane?
You need to read the tach manual. There should be a setting for multiplier to get the proper reading. These are designed to work on multiple engines with different numbers of cylinders. It sounds like you need to set it for X2 to get the right reading.
Your manual at 4.2 explains this setting.
BTW, the 4 Stroke reference means nothing. I see that on a number of these gauges and it is just an incorrect reference. Makes no difference 2 stroke or 4 stroke. It's all based on an electrical pulse to the tach. I think the Chinese are confused
This is what I expected. The bike has two coils one for each bank of 2 cylinders. The tack is connected to one coil so only see's one signal...although it might be the same timing as the other coil...I'm not that well versed on CBR ignition. OP should still try other settings on the tach to see what happens since he's getting half the RPM.
