-   CBR 600F (https://cbrforum.com/forum/cbr-600f-15/)
-   -   How To: CCT (https://cbrforum.com/forum/cbr-600f-15/how-cct-40124/)
drakito May 25, 2007 03:18 AM
How To: CCT
First remove the lower fairings, the cct is below the carbs, above the starter, hidden in the middle of a water neck. You should use a gasket though some people do not. A little rtv goes a long way;). Also torque to 15ft-lbs and apply loctite.
http://img509.imageshack.us/img509/9366/83mp6.jpg
http://img440.imageshack.us/img440/9343/84hx1.jpg
http://img509.imageshack.us/img509/3581/819ns4.jpg
that's it really, the rest is about head disassembly and reassemble, and checking tolerances.
enjoy
rrasco May 25, 2007 01:19 PM
RE: How To: CCT
Nice post, were there supposed to bethree images? Only the second one is showing.
I pinned this since it is a pretty common question too.
drakito May 26, 2007 06:25 AM
RE: How To: CCT
Yup 3 images, they all show up when I check the page too.
rrasco May 27, 2007 03:52 PM
RE: How To: CCT
ya, they are showing for me now.
letz827 Jul 22, 2007 03:25 PM
RE: How To: CCT
Has anyone been able to remove the cam chain tensioner without removing the coolant hose that runs right next to it? I am having trouble getting a wrench on one of the CCT bolts because the hose is in the way.
Chunk3rs Oct 9, 2007 09:58 PM
RE: How To: CCT
So where did everyone buy their CCTs? Is any one better than another?
Thanks
drakito Oct 9, 2007 11:04 PM
RE: How To: CCT
I got mine from www.servicehonda.com ,RRasco put me on to them. Way cheaper than my local dealer. I've also seen the manual ones on ebay and other bike sites.
camoweasel Mar 11, 2008 12:20 AM
RE: How To: CCT
I just replaced my CCT with another factory CCT. By removing the left fairing I was able to use a small 1/8' socket and extention to remove both bolts from the CCT. The only problem I ran into was the coolant hose. Fortunately I was able to remove both bolts. Fortuntely for me I was able to reuse the old gasket. Overall it wasn't a bad job. My only problem right now is that I can't hear whether or not I fixed it because right now I'm fabricating a new piece of pipe for my exhaust so right now with straight headers it's to loud to tell.
stinemonster Aug 7, 2008 10:43 PM
RE: How To: CCT
Manual CCT
It is easier to install a regular OEM CCT then it is to install an aftermarket Manual CCT. The OEM CCT is about the same cost as an aftermarket Manual CCT.
The OEM CCT part number is 14550-MN4-023 and can be purchased from servicehonda.com.
The Manual CCT shown in these instructions was purchased new off of eBay for about $50.
If you want to see how to install a Manual CCT, check out the pics and instructions inmy next few posts...
stinemonster Aug 7, 2008 11:18 PM
RE: How To: CCT
This First picture attached shows the instructions that came with the Manual CCT.
[IMG]local://upfiles/28770/9C5BF3AB4F6B40FCAAD902A0D4F3A2FE.jpg[/IMG]
