Hey there guys, New to CBR owning, quick Question
Hye guys, I just finally got my hands on my dream bike, a 1989 CBR 600F Hurricane. I love the damned thing, everything is godd except that the idle point for the engine I think is too low, it hovers just bellow 1000 rpm, so it sometimes stalls.
Any way I can quickly adjust it up so it stays just about 1000 maybe 1100 rpm or so, without having the remove all the fairings? Let me know guys, and thanx in advance. Alex aka Eclipse |
RE: Hey there guys, New to CBR owning, quick Question
My F3 has an idle adjustment knob [ I wrote, "knob" ! ] on left side poking [ I wrote "poking" ! ] through the fairing, maybe not for yours. Hey, did you post on the T.O. forum?
I have a 89 hurricane as well, it seems you may have a inherent problem, as mine does the same thing.What I did was tighten the adjuting knob, then set the idle to approx 12.000 rpm and it seems to hold steady.According to the mauel (I have one) it should idle around 12 to 13.BTW I love this bike as well, needs new fairings but goes like spit.
ORIGINAL: brian then set the idle to approx 12.000 rpm and it seems to hold steady. |
What would happen performance wise, if the idle was too high?
I have an 88 F1.......my idle was too high for awhile when i bought it...its been jetted and has exhaust...i attributed it to that until i read the manual....when your fairings are off (mine always are..the bikes naked) you can reach down into the engine are with your left hand and find the black idle knob...adjust that to about 1,200 rpms. Its great for me that my bikes naked...i can just adjust it depending on the weather:)
remove left side access cover (the small one).
get flashlight and look behind carbs for a knob attached to a rubber hose. it should be protruding from the middle set of carbs. this is your idle adjustment. start bike and let warm. or if starting to stumble, adjust idle till tach sees 1200-1400 rpm. let bike continue to warm up and then adjust accordingly. i have a wire hook made from a coathanger that i use to keep the idle screw captive close to the access panel that way should i feel the need to make adjustments i do not have to hunt for the adjuster. this will save you time and some skin. michigan_313 |
sweet thanks! my bike is idling a little low as well.
