HELP with throttle tube
Old May 24, 2016 | 08:56 AM
Zburna's Avatar
Default HELP with throttle tube
Okay guys first let me introduce myself im Zburna from oakland ca, a first time rider. I have a 1988 Honda hurricane 600f (first bike). Im a complete noob and trying to learn as i go. Okay what the problem is, the throttle was getting stuck so i removed my grips and discovered the original throttle tube was split which was probably why it was sticking. When i tried to remove it I noticed the cables were real tight and just broke the tube to remove it. I ordered a replacement (not original) and since then havent been able to get it to connect. I tried adjusting the adjusters but still didn't fit. How can i get these cables to fit on the new throttle tube? (New tube is suppose to fit perfectly.)
Old May 24, 2016 | 09:10 AM
coalminer frank's Avatar
Try removing the handle bar from the bike without disconnecting anything else. Should give you a little more slack maybe.
Old May 25, 2016 | 10:32 AM
dennisgb's Avatar
Pictures would help. A little hard to follow what the problem is.
Old May 26, 2016 | 12:02 AM
Zburna's Avatar
http://i53.photobucket.com/albums/g56/zion_jones1/Mobile%20Uploads/image_zpsd2mhcflj.jpeg
http://i53.photobucket.com/albums/g56/zion_jones1/Mobile%20Uploads/image_zpsukol2iyb.jpeg
Cables too tight one size fits the other doesn't.
Old May 26, 2016 | 07:36 PM
drakito's Avatar
LEt me help you there
Old May 26, 2016 | 10:57 PM
Zburna's Avatar
thanks tried to do it from iphone
Old May 27, 2016 | 12:46 PM
dennisgb's Avatar
Still not very clear what the problem is. Are you saying the cables won't fit the ferrell holes? Are the cable diameters too large to fit the groove in the throttle? Are the cables too short?
If it is a length problem you may need to loosen the cables at the carbs to get them on, then readjust. Or take the bar off so you have slack in the cables while you assemble.
Old Jun 3, 2016 | 03:27 AM
Zburna's Avatar
The cables are short possibly not what the bike was not meant to have. Unfortunately i cant even get to the carbs because previous owners hadn't opened them up for years so they're stuck. I tried wd 40 doesn't work I think i have to take it into the shop as soon i can get enough money.
Old Jun 3, 2016 | 10:15 AM
dennisgb's Avatar
If they fit the old throttle tube they should fit the new one. If the carbs are stuck the cables won't move so only way to get them into the tube is to loosen the adjusters at the carbs. Stuck carbs is likely what broke the old tube.
If your carbs are stuck WD40 likely won't help. You might get the throttles to move but being stuck indicates long time sitting. In that condition carbs likely need to be rebuilt. This could be costly in a shop. If your new to this doing it yourself is a major challenge.
notny41
Nov 5, 2007 01:10 AM
MDiMatteo56
Mar 18, 2007 05:40 PM
