Help Cleaning Carbs Plz?
Old 01-21-2011, 10:27 AM
jakethesnake's Avatar
Red face Help Cleaning Carbs Plz?
ok so i just bought a 89 cbr 600. it starts up fine and will idle all day but it starves for gas and when it does take the gas it hesitates and spits and spudders. it will rev to about 5k and then after that it wont go to much further. i dont know to much bout bikes but im 99% sure its just that the carbs need cleaning? and i was wondering wat the best or easiest solution would be to fix this problem?
Old 01-21-2011, 11:56 AM
thrasher572's Avatar
Start by removing all the stuff that is in the way. Bodywork, seat, fuel tank, air-box. Inspect the air cleaner while you got it apart. Undo the four carb boots and throttle cable. Remove the carbs. Drain them. Flip them upside down and remove the float bowls. Start cleaning.
Old 01-21-2011, 12:17 PM
so its that simple? ahah i figured it would be alittle difficult? any ideas on what to use to clean it with?
Old 01-21-2011, 12:33 PM
Use carb cleaner. But from what you are describing i would make sure your choke is not stuck on.
Flip them upside down, remove the floats, remove the jets, make sure you clean the jets very well, you should be able to see light shine through them when you are done. Also spray through all passages in the carbs, make sure your slides move free, check the slide cut off valves. When reassembling make sure you take your time setting float heights and sync the carbs when you are done and reinstalled.
While you have them off check and maybe replace your intake boots. When they get old they get hard and can let air in leaning out your mixture.
Old 01-21-2011, 12:37 PM
Good detail 6 fm... I use Gunk.
Old 01-21-2011, 03:57 PM
do you HAVE to dissasemble the carbs? jw?
Old 01-21-2011, 04:03 PM
Yes, you do to get them clean.
Old 01-21-2011, 06:44 PM
tripicana's Avatar
it helps to completly take them apart. you will need to syncronize, and might replace some seals.
before you pull them, make sure all the chokes move together, and that none of the hardware is loose. careful with the float bowls and slide covers, the seals like to stick and will split easy. download and read the manual how to bench snyc the carbs, if you get all the throttle valves open to the right position, it should run well.
Old 01-22-2011, 09:32 AM
in the past i have just taken carbs off and soaked them in kerosine for 3 or 4 days and you would really be surprised wat that would do. thats why i was wondering =P
Old 01-22-2011, 12:06 PM
You have a very understanding wife or girlfriend trip.....
Quick Reply: Help Cleaning Carbs Plz?
