having cold start problems
hey im having trouble starting my new bike, po says it dosnt like to start when its cold, and when i try to start it i smell fuel faintly, what could i do to help this? should i clean the carbs of try something else? this is my first bike. and im more familiar with fuel injection, but i am pretty mechanicly inclined, just want some advice b4 i tear into it if i dont need to thx
first off use regular gas, not high test. regular burns easier and faster.
second, heres what i do. go full choke, give the throttle three full turns, they attempt to start. if it doesnt want to start still try holding the throttle open a crack while holding the start button. that and i also make sure to start the bike once every other day at the least. i usually start it for like 5 min every day.
I have an '87 that I bought last fall as a basket case. I put it together and now I am starting to tune it for spring. It took a lot of cranking to get it to start. I used full choke. I let it warm up for a while but could not get it to stay running with the choke off. I will be pulling the carbs shortly. My idle circuit must be gummed up from sitting.
