Got dumb questions, Need anwsers?
Old Oct 15, 2007 | 09:40 AM
daytonatrbo's Avatar
Default RE: Got dumb questions, Need anwsers?
ORIGINAL: rrasco
Its hard to tell if there is water in the reservoir, I cant ever tell and over fill it. Just remember it only takes 2L. Make sure you don't use just distilled water either, it will oxidize the aluminum block over time.
if you run straight water, not only will your block corrode internally, but your water pump seals will blow out. antifreeze has oils in it that condition the seals in the pump etc, as well as protecting the metal parts.
Old Oct 15, 2007 | 05:35 PM
Billistic's Avatar
Did you take off the gas tank and actually open the radiator cap to see if there was any coolant in there?
Old Oct 15, 2007 | 09:44 PM
svx96's Avatar
No I didn't take it off I was looking in the reserve tank. How do I go about taking the tank off? Is that nessary to do to fill the radiator? Thanks
Old Oct 15, 2007 | 10:13 PM
Billistic's Avatar
Yes absolutely. Take off rear side covers,then seat. Tank has 2 bolts. You can place tank on rear subframe
if you undo fuel filter and fuel line from their stays. Then you will see radiator cap in front of air box. I use some good old Prestone.
Old Oct 16, 2007 | 05:54 PM
ispidey's Avatar
this website has a good parts fiche that can help you see how stuff comes apart:
www.bikebandit.com
Rs2nV
Apr 14, 2010 11:55 PM
BooDio
May 6, 2009 11:45 PM
voodoochyl
Jun 22, 2008 01:56 PM
rd05f4
Mar 9, 2008 02:18 PM
URRslow
May 17, 2007 06:45 PM
