f2 front end in hurricane
i bought this part very cheap, now i will need a wheel and this is the question, if i want to use another wheel, what mothel can fit in this front, maybe a 929 or f4 or cbr600rr, i really don,t now.
i don,t now if the rotor will fit the caliper
f4/i maybe, but 929 and 600rr definitely not. the axles on those have a much larger OD. also, they use different size, offset, and bolt pattern rotors.
try to find a f2 rim and looks like you'll also need the calipers. i believe you can even use the f3 rim and calipers if you needed slightly more options. but for the most part, everything past 98 is a no go.
you could probably find a set of f2 calipers for cheap and just get a rebuild kit. the rim may cost you a bit more. if you want a 3 spoke rim that will fit the forks, you may be out of luck on that front. i know for a fact that the hub section of the 600rr rim is much wider than the f2 rim side to side because the fork spacing is also designed wider for more stability.
TechGirl1414
Aug 23, 2011 06:13 AM
