F1 600 Battery Relocation
Has anyone successfully relocated or modified their battery/battery box?? I'm turning my busted 87 into a streetfighter and am trying to clean up the tail and subframe area. My problem is this gigantic ugly box hanging out the bottom. Any advice is appreciated.
Check out Shorai battery for lithium ion batts. Can lay them on their side, maybe a small one can fit in the tail section?
That should work perfectly thanks
2 Attachment(s)
yer mines under my tank running standard battery but you lose are box i run k&n style single filter but you will need a rejet to about 120 on main for high rpm
fist off made this Attachment 28254 then fitted it here Attachment 28255 and a vid with the tank on it i shortened my loom down as well everything it under the tank and i dont run a fuel pump either |
Originally Posted by Andrew Frankenstein Knight
(Post 1281776)
fist off made this Attachment 28254 then fitted it here Attachment 28255 and a vid with the tank on it streetfighter build - YouTube i shortened my loom down as well everything it under the tank and i dont run a fuel pump either id appreciate any help you can send my way. cheers mate, daniel |
Anyone gott better photos of this battery relocation? They just aren’t super clear and extra pics would help a lot.
also did you run pod filters by any chance? any help appreciated |
