Engine woes...
Old Feb 7, 2008 | 08:53 PM
mj_wils1970's Avatar
Default Engine woes...
Hi,
I just got an engine that has been sitting for several years and I'm wondering what's the best way to get it running again. It was drained of all fluids before storing.
Thanks,
Mike
[align=left] [/align]
Old Feb 8, 2008 | 02:40 PM
michigan_313's Avatar
Default RE: Engine woes...
add back fluids. if possible, pressurize the oil passages so that everything is lubed before turning over.
turn the engine by hand to see if everything moves, pistons are not rusted into the bores, etc. remove spark plugs and spray in some wd-40 into the cylinders to get them lubed. once the engine starts up, it will all burn away, so don't worry about the smell and smoke.
should be okay.
on the carbs, you may need to clean them of any old gas or gummy buildup in the passages.
M@.
Feb 26, 2013 05:26 PM
f4izombie
Jul 1, 2011 07:27 PM
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
camaropower
Jul 29, 2009 07:48 AM
kpnupe
Feb 24, 2009 08:46 PM
