electrics!!
Old Jul 5, 2008 | 11:44 AM
newnut's Avatar
Default electrics!!
any ideas whats stopping both my fuel pump from working and stopping the baby sparking? new cdi, regulator coils & leads battery, no joy, im at a loss! would the safty switches effect both as i've noticed the previous owner has butchered out the side stand switch!
Old Jul 10, 2008 | 12:53 AM
Billistic's Avatar
Default RE: electrics!!
Definitely the side stand switch as a possibility. If the switch is not making contact then the bike will not start.
I used an '89 CDI box on my "88 Hurricane which has no side stand switch. I had to install a wire from the CDI box to ground so the bike would start. When the side stand is up, the switch shorts something in the CDI box to ground. Check the wiring diagram and you will see.
Old Jul 13, 2008 | 04:13 PM
newnut's Avatar
ta! i have an 89 cdi with no side stand switch pin, did this just erase the problem for you just simply swapping them over?
Old Jul 15, 2008 | 10:10 PM
Billistic's Avatar
yes, since you actually have an '89, then try this. Locate the 3 pin connector that the side stand switch connects into the main wiring harness. Disconnect it and put a jumper wire on the harness side of the connector between the green and green\white terminals. This will be as if the side stand is up and your bike should start ( assuming that's the only problem ). PM me if you have further questions. Good luck. Hate to be obvious, but I assume that all fuses are good ,ignition is on and engine stop switch on throttle side is engaged.
hawkwind
Feb 10, 2015 12:56 AM
seralph
Mar 5, 2013 01:16 PM
finnishcbr
Jul 9, 2012 01:43 PM
ninjapower
Jul 9, 2009 04:08 PM
ninjapower
Jun 29, 2009 01:43 PM
