Did I do the adjustment right?>???```
Old Oct 2, 2007 | 12:58 AM
psharma's Avatar
Default RE: Did I do the adjustment right?>???```
according to a 600 F(M) manual cylinder #1 is on the same side as the alternator, which is the right side of the bike when you are sitting on it. my bike is the F(H) model so i used the same config's when i was doing my valve adjustment. The manual says to line the "T" mark with the TDC on the crankcase cover so i did, then it said that i could measure intakes of 2 and 4 and the Exhaust of 3,4. So i figured out that cylinder 4 was the left side (when your sitting on it) because i tried to measure #1 (right side), thinking it was #4 and there was no clearance. So if anyone with a 600 F(H) has a different type of config you should let me know
Old Oct 2, 2007 | 01:34 AM
Gogar's Avatar
Psharma, If you're on the side of the bike with the clutch, alternator, oil filler, timing marks, rear brake, etc., the cylinder closest to you is #4. Put the spark plug wire with the 4 on it in there. Then 3, 2, 1 going away from you. 2 and 3 wires come from the side of the bike you're on, and 1 and 4 come from the other side.
Old Oct 2, 2007 | 02:28 PM
psharma's Avatar
on my bike the clutch, alternator, oil filler are not on the same side, the alternator and oil filler are on the side with the rear brake and the front brake the right side of the bike when your sitting on it
Old Oct 2, 2007 | 03:14 PM
Gogar's Avatar
Sorry dude. What I mean is the clutch on the engine, not your hand. Yes the right side of the bike when you're sitting on it. The alternator and the clutch are both behind that "crankcase cover." And the cylinder right above that cover is #4.
Old Oct 2, 2007 | 10:08 PM
psharma's Avatar
cool thanks for all the help i got her up and running i put the spark plugs in the right place but it still didn't sound good and it wouldn't really start once i changed the coil for 1 and 4 i got it running good
[align=left] [/align]
72tx340
Jun 4, 2012 08:13 PM
J_Hairston
Sep 19, 2008 03:33 AM
dirtysanchez
Aug 15, 2006 08:03 PM
8UR VET
Jun 30, 2006 09:00 PM
