Cylinder head removal
Hi all, got around and started removing my cylinder head to remove a blown gasket. I removed the 12 nuts inside the head tho it wont come lose and when i try to lift it with a lever i ended up lifting the cylinders to. Its stile all in place tho cant figuer out what i am doing wrong. Any help?
Are there 2 smaller bolts by the chain?
Originally Posted by 74demon
(Post 1286121)
Yes i did. Ellse the chain wont come loose |
No, the ones that bolt the head to the case under the gears.
(Post 1286126)
The cylinders float, I believe. They may just be stuck....
The bolts connect the head to the block. If the head is loose, then you got them or don't have them. |
(Post 1286128)
Not for an F1.
I'm just guessing on your specific motor. If the barrels are loose, then they are of the floating design. Otherwise, you would be in BIG trouble.... |
Caveat - my suggestion is based upon removing heads from other engines, not CBRs - If there is nothing else holding the head down you might need to smack the head on the sides with a rubber mallet to break it free from the head gasket.
Originally Posted by Doc B.
(Post 1286131)
