cracks in frame?
I have looked at 3 hurricanes recently and all had a crack on the frame in the same place. The crack is on the underside of the main frame rail just in front of the rear motor mount. Any ideas? What do you think causes it? I have stripped one bike down and had the frame welded.
All the bikes were from different owners... the crack is forming on the left side main spar just in front of the guide for the top, rear engine mount. The crack itself extends around the bottom of the spar and it is on the larger of the two frame sections...behind the weld. It looks like a stress crack. There is no obvious damage anywhere else on the frame. The odd part is that the crack has not appeared on the copy I bought new. I aquired two of the bikes very cheap because of the frame damage... I will take a picture and post it so you can see exactly where the crack shows up.
I have a theory about why they crack and why my original owner bike has not... we all know the high frequency vibration that is transmitted through the bike around 5500 rpm... That engine speed tranlates to 60mph of 100kmh in top gear with stock gearing.My bike has seen redline almost every shift for 20+ years and has not spent a lot of time in that rpm range and the frame is fine... I believe the frames that are cracking are on bikes that have been ridden "gently " and at or near the speed limit and in the high frequency buzz rpm too much. It is just a theory....
