Cleaning up the wiring ?
Old Jun 20, 2022 | 10:57 PM
NuggyBuggyCBR's Avatar
Default Cleaning up the wiring ?
Was trying to figure out if my fuel pump, and needed to figure out where the fuel pump relay was. I ended up tracing the wires from the pump wiring connector to it. A fairly large bundle of wires was wrapped in what seemed like a ton of electrical tape. My fingers are still sticky from peeling at it.
What's the best way to clean this up and keep the wires nice and tidy and secure? I was thinking maybe something like the stuff here: ?
Wrap Around Braided Cable Sleeving
If there's better stuff to use for use in a bike, or a better place to buy it, I'm all ears.
Thanks !
Old Jun 22, 2022 | 08:35 PM
stanthomas's Avatar
Ideally the wires would be inserted through a PVC sleeve but this is no use to you if you just want to wrap existing wiring. I use this convluted tubing in some applications, it's tough and can be retro fitted to existing wiring.
Alternatively you can get non-adhesive cable wrapping tape. It's just like regular, sticky, PVC tape but without the glue. Wrap it round with a suitable overlap then hold in place with a loop of sticky PVC tape (or a cable tie) at the end.
Old Jul 12, 2022 | 09:27 PM
@stanthomas just wanted to let you know I ended up buying the sort of adhesive tape you mentioned, as well as this stuff:
MGI SpeedWare Woven Mesh Split-Sleeve Wire Loom for High-Temperature Automotive Harness MGI SpeedWare Woven Mesh Split-Sleeve Wire Loom for High-Temperature Automotive Harness
. Thanks for the suggestion !
Christo Christo
Nov 8, 2020 04:00 PM
trachito
Jun 7, 2019 09:13 PM
IDoDirt
Jun 19, 2016 10:35 PM
Kitty
Feb 16, 2013 05:36 PM
oldschoolCBR
Apr 16, 2007 11:56 AM
