charging system problem
RE: charging system problem
you could try your local electronics supply store or online store,but my guess is that you may just need to get a completely different3 or4 pin molex connector and redo both the female and male connections. the oem connectors arepretty hard to find. should cost you no more than a few dollars for the pair.
try looking for something like this:
http://www.kayjayco.com/catPConnectors.htm
http://www.suresealconnections.com/orderSamples.html
http://www.sherco-auto.com/cg.htm
ok so i put in a new connector and i started it fine before i started it the batery was at 12.6 and after i started it it slowly increased to around 13.5 and when i hit the gas up to about 5k rpm it would increase then after 5k it will stop. is that right i am gonna post back after i get to ride it further then the 2-3 i did today and say whats happening
hey i rode my bike around for about 60-70 miles and i came home tried to start it this morning and it tried and then the battery went out just couldnt hardly turn the engine. i dont know where my problem lies any more. i am charging the battery and then i plan on starting it and checking the volts while it runs and revs. then my only other geuss it that the r/r stops working when it gets hot if the can even happen. any suggestions would help i thought the problem was fixed after i replaced the connection thanks again.
alright i am charging the battery now then i am gonna see if i leak any power while the bike just sits there key out and everything then i will check the r/r i dont think it is bad i think i leak power somewhere but ill check everything just for the peace of mind
ok so i pluged every thing back together and started the bike. the volts in the battery went up slightly and when i reved the engine up to 5000rpm the volts only every hit 12.8 or so. i didnt have the bike at normal operating temperater. i dont know if that effects anything. so the volts do go up a little but not enough to keep the battery tip top. anythingany ofyou can think of that would cause this. when i changed out the coupler i may have accidently mixed one of the wires up becuse my splice came off of two of the wires at the same time and i tried to hook them up right but not sure. could that cause this? any help is again appreciated.
thanks again
thanks again
