Chain removal
Chain removal
Getting the chain on and off apparently sucks, they made it way to hard. I am thinking about dropping my swingarm to replace the o-ring chain, to avoid buying a press or paying for a freaking chain replacement. Anyone have an easier way, or know what problem I could run into by doing this? (i.e. the shock will be a bitch to get back into the swingarm)
i've removed my swingarm. the hardest part is getting it supported. two friends lifted while i put the jackstands in place. everything after that just unbolts. loosen all the tight stuff, like axle nut, and swingarm shaft while the bike is on the ground first.
if you're getting a new chain, i would just cut the old one off. i recomend the proper tool for rivet type chains. but, you might get away with using a vice and steel BB on the rivet.
What is your time worth? I'd rather not risk the bike falling off the stands and buy the tool. 30 seconds with the grinder, 2 minutes with the chain break tool. Re assemble the master link and rivet it all with the same tools.
You will wonder why you would ever try it any other way once you have the proper tool.
WhiteHawk
How To's
05-03-2014 08:13 PM
eekenterprises
01-19-2009 09:05 PM
