Chain isnt fitting right
Hello, I bought a 1988 Honda Hurricane 600 last week and ever since i brought it home the chain has been very noisy at crusin speed. I changed the sprocket to the orginal on and still the same thing. If i jack the back off the ground and spin the tire i notice the chain gets tight, then loose again, so something is messed up. I have noticed from the rear the tire is not exactly in the center of the tail and was wondering if it is possible that the swingarm is bent. If anyone has a hurricane and can check to see if the tire is in the center of the rear that would be great. this would most liekyl be the cause of the noisy chain. Thanks
I had the same problem with the chain getting tight and then getting loose as I spun the wheel. New chain and sprockets took care of that issue. I agree with Tripicana on the possible bent subframe. Nice thing is, if it is a bent subframe then you and a friend can bend it back.( but not bend it like Beckham, unless Posh is there).
well i took everything apart and checked the swingarm bushing and everything.. everything looks great so i put it back together and lubed the shat outta the chain and it seems like it defo. could be a stretched chain.. so i guess i will be ordering another one with the sprocket.. Thanks everyone
