Carb Cleaning Question!!!!Bike Died at 65!!!!
#21
RE: Carb Cleaning Question(Doing it right now)
Hey im trying to get those inside limiter caps off, but am having no luck is there any real good trick, or do i have to sit there and pull pull pull and nothing til it pops off?
ok so i gave up for the day on the inside limiter caps tried for literally an hour on one and about half hour on other, scratched then a bit but nothing major, i adjusted the outside too, there are at 2 3/4 turns.
also previous owner said it was jetted but when i was going through cleaning the carbs the main jets didnt have any numbers or anything on them to tell me what they are, is that strange or what?
#22
#23
Acetone (i.e. nail polish remover) is supposed to be able to remove loctite.
http://www.cyclingforums.com/archive.../t-127417.html
I think it's pretty safe, but I'd still be careful to not get it on anything painted/rubber/plastic etc. A little paintbrush or something would work to control where it's applied.
#24
Ok so i thought i fixed the problems, new spark plugs, cleaned carbs, new r/r and it still dies while riding.
Ok heres what happened got it running yesterday everything same adjustment, and new sparks helped to make it fire up with no choke, i took it on a 23.7 mile ride no problems. Today I got about 5 miles and at 65 miles an hour i let off the throttle, bikes at 0 rpms, tried to start wouldnt start.
I look over and my chokes a bit on, idk if it flood from that or if i have other problems somewhere?
#25
what gear and rpm were you at when it happened? If your bike is jetted, does that include needles? If so, 2 3/4 turns on the pilots seems like too much and you might have flooded it if in high-gear/low rpm. ... or you may have just ran out of fuel (oops). Perhaps a short in your kill-switch... I would make a list and start an elimination process of possible problems/solutions.. eventually you'll find it and laugh about it.
#26
I was in 5th or 6th not positive around 6k or 7k doing roughly 63 mph. I put clutch in and hit the brakes and then rpm right to 0, tried to start it but it sounded really weak like battery was dead.
But something i noticed right before this was i put it in nutruel at the end of my street with turn signal on, and everytime the turn signal would blink it would dim the nuturel light, is that a short or battery or do i have to get another r/r? Battery is a gel, but its been ran down several times now, only 3 months old.
Oh and the jets i was looking at my pictures i took when it was apart one of the jets had a #35 on it, isnt that stock? But the others had nothing and look the same.
#27
#28
jbalber
F2 Tech
10-02-2012 05:52 PM
