Carb Cleaning Question!!!!Bike Died at 65!!!!
Ok so i just took my carbs off and they are a bit more dirty then i expected but oh well. My question is on the outside of the carb theres alot of dirty grude, can i just hit that with carb cleaner or do i have to remover all the rubber hoses and other stuff? Heres a few pictures, some of the springs are gummed up. Let me know asap
RE: Carb Cleaning Question(Doing it right now)
The exterior of the carbs doesn't matter as much as the internals
although those springs shouldn't be restricted too much either. If
you have no trouble removing the rubber boots and putting them
back afterwards, it wouldn't hurt to do it and do a good cleaning-up
job.
On a sidenote, try to put a break between those pics when you post
them, I'm sure most people don't have screens wide enough to view
them all without scrolling from left to right
job.
Ok well i played with it for a while, and it started up and its running, seems better then before, due to i can turn it off and turn it right back on. But the exhuast sounds more aggressive, and not as high pitched as from before, is that normal?
