Can TRAC be 'turned off'??
Now that I was able to get some real miles on the bike, I've uncovered another 'problem' that I have no base of knowledge on.
When front wheel braking, I can feel a pulse in the lever when coming to a stop. The caliper is visibly moving in and out from the fork slider.
First question is, is this a sign that the anti-dive is 'working' or not?
Either way, can this be disabled? If not, is there a fork from another model, say a VFR be slid right in?
Check rotors and pads first.
There should be no pulsation. The anti dive works under hard braking by engaging a piston in the bottom of the left fork, firming up the bound on that shock. It has no change to rebound in any way. It should smoothly actuate without you feeling a thing other than the front not diving.
