Anybody running without an oil cooler
Old 08-25-2009, 10:23 PM
KongBastard's Avatar
Default Anybody running without an oil cooler
Just like the subject says. Anybody?
KongBastard
Old 08-26-2009, 02:05 AM
michigan_313's Avatar
alright, spit it out, what are you thinking about doing?
Old 08-26-2009, 03:35 PM
removing my front fairing (whats left of it anyway) and mounting the oil cooler somewhere else.
Looked at it in a few different spots and was thinking that I may just turf it all together.
Sorry for the crap pictures.
KongBastard
Attached Thumbnails Anybody running without an oil cooler-front.jpg   Anybody running without an oil cooler-left.jpg
Old 08-26-2009, 04:54 PM
maybe make a couple of brackets to mount right under the radiator. or maybe side mount it vertically?
Old 08-26-2009, 08:02 PM
heresolong's Avatar
I would definitely not run without. Someone did the testing and decided that the oil would run too hot unless they added a cooler. Otherwise it would have been cheaper and easier to build the bikes without. You risk damage to your engine if you remove it.
Old 08-26-2009, 09:57 PM
I assume by "someone" you meant the factory? Good point.
I don't have any fairings mounted so the hot air isn't as likely to get trapped against the engine.
KongBastard
Old 08-27-2009, 08:47 AM
cbreric's Avatar
but at the rpm the motors run at the oil is getting heated pretty well, even with no fairings mounted. on a side not, I like the look of the bike as it is, and what exhaust is that? good luck with whatever you decide
Old 08-27-2009, 12:29 PM
Exhaust is a D&D. I painted it black and put the brass (actually aluminum) knuckles logo on the can.After that picture was taken I cut a few inches off the can.
Here are a couple of newer ones (sorry for the cellphone quality pics).
KongBastard
Attached Thumbnails Anybody running without an oil cooler-_longjpg.jpg   Anybody running without an oil cooler-_short.jpg
Old 08-27-2009, 02:09 PM
thegreenbandit's Avatar
I think your Oil cooler is more important then your rad. If you look at older Honda's like the night hawk etc they don't have a rad but they have an oil cooler.
It's also a part of the system to keep your oil circulating. Which helps improve the engines longevity. And certain parts from overheating more then others.
Old 08-27-2009, 04:29 PM
cbreric's Avatar
night hawk is air cooled....
Quick Reply: Anybody running without an oil cooler
