Alternate Piston?
Old Apr 25, 2008 | 03:11 PM
mj_wils1970's Avatar
Default Alternate Piston?
Hi,
Has anyone had any experience using an oversized piston other than OEM spec? As I cannot find any OEM or aftermarket options, I may have to look for an alternative. If there is no such option, has anyone tried an F2 motor? ( I understand there may be alot of fabrication, but that's what makes life fun!!)
Thanks,
Mike
[align=left] [/align]
Old Apr 25, 2008 | 03:25 PM
dalex's Avatar
Default RE: Alternate Piston?
You're not lucky, I just threw out a set of 0.25mm O.S. pistons. I didn't know I had them until I got a cylinder block to replace the one I had which had the sleeves in really bad shape, then the OS pistons wouldn't fit. I ended up going back to stock specs and got stock size pistons to go with the block. Before I knew what I had, I was looking for OS pistons too and just couldn't find anything, anywhere. Could've gotten custom fabbed pistons for about $100 a piece. Definately not worth it.
As for the F2 engine fit, you're right, many will agree that it'll take quite some fabbing and a lot of man-hours to do it.
Hope you don't mind me asking, what are you trying to accomplish? Engine re-build w. overbore or just looking for more power?
Old Apr 25, 2008 | 03:45 PM
Hi,
I'm rebuilding the bike from a box-o-parts... it's been alot of fun so far but the worst part was the compression test...
80-0-60-45
So there's a dump somewhere with pistons???
[align=left]
Thanks for the reply!
Mike
[/align]
Old Apr 25, 2008 | 03:57 PM
dalex's Avatar
Did you forget to put the rings back on the piston #2?
J/K, hope you get it fixed, this bike's a lotta fun when running well and the sense of accomplishment undescribable.
As for the compression test, you should only do it when the engine is already warmed up. On a sidenote, you can also loose compression through the valve head, not just pistons.
Old Apr 25, 2008 | 04:52 PM
Hi,
The engine was the only thing that wasn't in a box
Either way, it's a fun thing to work on when the wife's asleep and one day, it will be on the road again.
Mike
CBR1988
Alternative Parts
Feb 15, 2013 10:32 PM
this guy
May 18, 2011 02:33 PM
ged9
Apr 30, 2008 10:14 AM
thrasher572
Jan 18, 2008 01:38 PM
