Almost done.
Old Sep 19, 2006 | 03:43 PM
ajscbr600's Avatar
Default RE: Almost done.
Thanks for the comments guys. I do like the way it looks, but there are gaps that I hate. another problem is, with this plastic my guages will not fit in there, and you can see right inside my front fairing. i don't know which way i will go in the way of the swingarm. I just wanted at least a 180 series tire on the back. My dad is an R&D machinist for a living so the machining of the frame and swingarm will not be a problem. I still can't decide if I want the 900rr tail so it will match the girth of the stock hurricane plastic. I will keep you guys posted as this progresses, and if anyone wants to trade i will give it all except for the tank. even the flush mounts that are on there. you would have to make your own upper mounts, mine are just two bent pieces of aluminum. and two tail mounts, or you can have my mounts but i warn you they are not pretty. I was going to weld up a custom subframe, but now my plans have changed.
