520 kit easy to install?
Guest
Posts: n/a
just picked up a new 520 kit for a hundred bucks from a kid who bought if for his f2 build but it wouldnt fit, it didnt have the master link though will my stock master link fit on this chain? also i shouldnt need any special tools to put it on right? i was told its not rivited so its easy
any time you're dealing with chains, dont use a previously used master link with a new chain. its just BEGGING for problems. get a brand new master link and dont sweat it.
installation should be simple. remove your old chain, take the rear wheel off and use the appropriate size socket to remove rear sprocket, though I recommend keeping your old chain on to hold front still while you remove the nut, THEN remove the rear wheel and sprocket.
bring your chain with you when you buy a master link. you need to use a specific link for the chain. like previously said, dont use an old link. i just put a new 520 sproket and chain on my bike. i had to cut links off to make it fit, and i had to rivet the new master link on.
Dont use a clip style link on any street bike. Like said you will a master link match to what ever brand n pitch (520 etc) chain that is. Stock pitch is like 530/535. Different manufacturers use diff size pins too, so get a EK for a EK, RK for a RK etc. Its best to have a rivet press tool, but it can be done with a hammer n punch.
I"ve run clip style links before. ONLY if they are incorrectly installed do they come undone. open end should be facing rearward on the TOP side of the swingarm, so that inertial forces dont allow it to slide off.
but I like the rivet style link. when installed, ABSOLUTE ZERO CHANCE OF FAILURE if assembled correctly.
and btw, a DID 530 master link fits an RK 530 chain just fine. I accidentally ordered a DID link for my chain, not realizing I bought an RK chain, but it works just fine. fit is the same as the RK master link.
Guest
Posts: n/a
well almost done guys!!!!!! so far so good with everything im just waitin to go to the dealer to get a masterlink tomorrow i saw a video of a guy doin everything the cheap way like using jack stands to jack up the bike i just have two bottle jacks under the swingarms lol. if its the rivit link he used a c-clamp to close the link so well see i guess!!!!! ohhh hey will i notice a big difference in highway speed with this 520 kit? its a 15t front and 47t rear
ORIGINAL: vdubracer33
kreush33
Jun 4, 2006 01:43 PM
