1990 hurricane running great 3 days ago. Now WTF?
http://regulatorrectifier.com/catalog/
there are cheap. buy a new one.
But your bike should still have power, it will just kill the battery when its running as all that does is convert the charge from your engine to charge the battery......
If your battery voltage is good and the 30A fuse is good then it must be a connector, the ignition switch or a fuse. Do you get battery voltage at the ignition switch? One other thing as stated by Mr. Logan Hudak, if your Regulator/rectifier (R/R) has gone bad( which they often do on these bikes) then you will be running on battery alone until the battery dies. It converts the 3 phase AC voltage from the stator to the 12-15 volts DC that the bike uses and also charges the battery. Try to jump start your bike with a good car battery with the car NOT RUNNING. Does the bike start? If so then your battery may be toast. Why then is the battery toast? Bad R/R? You CAN troubleshoot this. We just need more info.
I've read here and elsewhere, it's because the charging system in a car/truck is vastly more powerful than a bike, and will seriously damage the bike if it's running. If the car is off, you're basically just hooking it to the battery alone, it could be just sitting on the ground for all it matters.
Here ya go, tech talk. My step dad is an electrical engineer.
"Amps is current and only the amount required for the load will flow for
a given voltage (V = IR).
Basically the battery will produce a lot more current than the
alternator, since it takes 100s of amps
to start the car - so the amps comment isn't correct. To charge the 12V
battery, the alternator will
Put out (while the car is running) a higher voltage, like 13.5-14V to
charge the battery, that's why
there is a regulator, to regulate the voltage. As long as your bike
uses a 12V battery like a car, it
would be fine."
would be fine."
would be fine."
would be fine."
Some of it is an old wives tale most likely
The only real issue is if you put the cables on the wrong terminals and voltage surge issues are probably worse if the car is running.
I think it is probably a good idea to shut the car off anyways
KongBastard
