1990 cbr600f won't start
I have been rebuilding a cbr600f and I was able to get it running, ran strong but the next day it wouldn't start at all,
It will on occasion hit giving a backfire I have rebuilt the carburetors, new pulse generator, new battery, I have also checked the coils and wires they are still at the correct resistance as stated by the manual. it almost sounds like a timing problem so I replaced the CDI with one from eBay, but i still can't get this to run ... looking for any suggestions, Im thinking that it is an electrical issue but since it ran for awhile (about an hour) I'm at a loss Thank you for any help you can give Mark |
Spark, fuel, compression to make it run. Which are you missing?
its all there spark, fuel, air and compression
It seems like a timing problem and if its not electrical then maybe its mechanical like the timing chain slipped a tooth but then would explain why it ran before, Im thinking a sensor, relay, or diode Mark |
It will still run if its a tooth off, just not well. Compression will be down. What are the compression #s for all 4 cylinders?
I would take another look at the carbs.
Originally Posted by hamlin6
(Post 1326812)
These bikes will will be hard to start if the pilot circuit isn’t clean and set right. To test the theory spray a little starting fluid in the carbs. If it fires and revs...carbs are not clean. |
Originally Posted by Mark Music
(Post 1326804)
It will on occasion hit giving a backfire I have rebuilt the carburetors, new pulse generator, new battery, I have also checked the coils and wires they are still at the correct resistance as stated by the manual. it almost sounds like a timing problem so I replaced the CDI with one from eBay, but i still can't get this to run ... looking for any suggestions, Im thinking that it is an electrical issue but since it ran for awhile (about an hour) I'm at a loss Thank you for any help you can give Mark I would like to thank everyone for their input , I checked the compression got a new cdi card, new coils and i even checked to make sure that the cams were at top dead center, after all that still got the backfire... in the mist of planning hari-kari it dawned on me that the only this i didn't replace were the spark plugs!!! Since the bike was running i didn't think of the plugs as being the problem but guess what they were the problem!! I have since replaced the plugs and she seems to be running fine... i know i will have to tweak it a little but it runs!! and I just wanted to say thank you for all of your encouragement and your knowledge!! Thank you Mark |
