1988 Honda CBR 600F-J
Hi there folks,
My bikes stopped starting!
My battery is full, both terminals are connected fine. Sometimes when I turn the key, cockpit lights come on which is just normal, push the start button and it bursts into life. After a few minutes the lights start to flicker and the revs drop to almost cutting out, then it either rectifies itself or it then cuts out... all the lights go out and it doesn't want to start. If I shake the handle bars it sometimes comes back on.
I know its an electrical problem as the engines well serviced and the battery is fresh. Where should I start looking/checking? its really getting to me!
The ignition switch could cause all those symptoms. You can unscrew it from the base of the lock cylinder and inspect/clean it and see if that helps at all. Also check the electrical connection at the end of it for corrosion or damage.
Also check the connection from the stator to the regulator/rectifier (3 yellow wires from the stator) for any melted connectors or burnt wires.. it's a fairly common problem on the older CBR's.
I know that both a fellow CBRforum member and I both had a problem with these symptoms. What ended up being the problem was that one of the metal connectors where the main fuse meets the solenoid was broken. This caused a condition where i'd be running just fine then as i'm riding then randomly i would lose power and the tach would jump and and down. A quick wiggle of the solenoid would seem to give a temporary fix, but buying a new solenoid was what we both eventually had to do
