Intermittent starting problem
My 1998 blackbird fails to start and the problem is intermittent.
When I insert the key and turn on the ignition, sometimes the clocks spedo needle doesnt rotate as normal, and I dont hear any sounds like I normally do, and the bike doesnt start when I push the start button. However, sometimes if I leave it for a while and try it again, it will start when I try later. Its very annoying, any ideas please? |
RE: Intermittent starting problem
I had this kind of fault on my CBR1000F.
Have a look at your battery fluid levels. Mine were down. Changed the battery and everything went back to reliable. |
battery is fine..
How about the connections at the battery, and the other ends of the two cables? Sounds like an intermittent connection in that area.
