Hard colt start carb 98XX
Hello,
Such a problem, it is bad to start up on a cold , with open suction, it is necessary either to turn for a few seconds o, it also starts up on a hot one after the crankshaft rotates three times. Best regards Artur |
Welcome to the forum Artur, when were the valve clearances last done:)
Originally Posted by CaBaRet
(Post 1320430)
Have you had the Carburetors Synchronised
Right Artur Valves done Sync done , hows the Battery?
Still voltage -12.53VDC
Power on - 12.24VDC Starter start -11,5VDC ,turns low, slowly rising |
When its running what is the charge into the battery at 5000 rpm
Idle 14.6V
5000rpm -14.35V |
