Advice please
Hi Guys,
I currently ride a cbr1000f but am looking at a Blackbird. The one I am looking at is a 1998 but it has the following problem "it is the master or slave cylinder rubbers that have worn and are leaking air in, therefore need replacing." Are these easy/diy to replace or is it a major strip down/ pain to do? Cheers for any advice given Rich |
i'd stick a fresher used master cylinder on it,
just one of those bits i'd not touch myself. |
Are you talking brake or clutch master cylinder?
Great choice on bikes. I have a CBR1000F and a CBR1100XX.
I'm not an expert on mechanical problems. The CBR1100XX has a linked braking system. It sounds like he is talking about the braking system since there are a couple of cylinders in the braking system. As far as fixing this kind of a problem I'd have no clue myself from that description of the problem. I'm not sure if this site has any of the shop manuals on line. I do know that the site does. Honda CBR 1100XX Service Manual 97-98 I believe it is the secondary master cylinder that he is talking about but not positive. Page 39 of the shop manual has a diagram of it. It is located on the front fork tubes so it should be easy to get at if that is the problem. I haven't heard of this type of problem before on an XX and I have had one for 5 years and am pretty active on a couple of different forums. I am a moderator on the CBRXX.Com forum. In the event that you didn't know in 1999 the CBR1100XX went to Fuel Injection. I personally prefer the fuel injection model myself. Some folks prefer the carbs. Some prefer the fuel injection. |
If its just the brakes that need doing then go for it.
You can get rebuild kits for the master cylinders and calipers. The brake bleeding process is a little tricky but not impossible. As a rough guide Caliper repair kits are around £27 each Master cylinder repair kits are around £33 each Slave cylinder repair kits are around £35 Worst case if you need to do it all should be less than £170 |
Thanks
Thanks for your advice. Missed out on the bike at last minute.
