2002 cbr1100 turns over but does not start
Good day
I hope i can get some advise. I parked my blackbirds and the next day the bike would not start the motor turns. I have taken all sensors,ignition , even the ecu I put all this into another blackbirds and it starts straight away. In my bike the motor turn, the light is connected, the fuel pump does not kick in( yes I did bypass it then It works) the big issue is that the little key reader light comes on when u turn the key but does not go off allowing u to start I have been thru the harness using a wire diagram ANF checked every wire 1 by 1. My next option is to pull the harness out 9f the running bike and test the harness don't know where else to look |
How many keys do you have for the bike
Same problem
I had same problem, silly question, but have u checked fuses, I did but missed one which is in a white box behind where the battery sits, fuse 30 amp had blown, soon as I replaced it, fuel pump kicked in.
.hope this helps |
