Douglas |
05-11-2017 03:26 AM |
03 BLACKBIRD fi AND FUEL GAUGE PROBLEM
my 03 blackbird while sitting in garage decided to not start , I have no error codes, grounds and fuses are good fuel pump relay is good , but the fuel pump does not run and the fuel gauge does its start up light trace up and down the scale,then settles on empty, but does not turn red, it stays black flashing , tank is full. This started when when my battery dropped dead, while on a float charger, I thought charger was bad, so I swapped it out with another one , and battery was dead, this after starting it 4 days earlier, after replacing battery these two problems showed up. Help!
