stalled 2006 wont start
Ok just took the seat and fairings off. Positive bat. cable was a little loose, no blown fuses and can hear the fuel pump buzz when turning the key on. Wont start kick stand up, down, or in nuetral. I can hear the fuel pump turn off and on with the kill switch. Under the seat there is a regular size 30amp spare fuse attached to what i believe is the stater siliniod, everything i see is mini fuses. Anyone know what that fuse goes to and is there any other fuses besides the 6 or so mini fuses under the left fairing.
Update, after being in two different dealerships for two months they found the problem. A small quarter size cap at the end of the camshaft came out and broke the end of the cam position sensor off. The sensor ohmed out good from the outside of the motor but wouldnt read the cam so in turn would give spark or fuel to the cylinders. They said they have only seen this once before and it was just back luck.
