sprocket help...
RE: sprocket help...
hardnened AL is the key to long wear
the vortex sprockets are not as hard as AFAM so they wear faster
if you stick with 530 you can keep the old chain
if you go to 520 then you must get a 520 chain as well
check out www.kneedraggers.com
they have chain and sprocket kits
http://www.kneedraggers.com/details/...RR--50875.html
this is what I have, what a lot of people have actually
The DID erv3 520 x ring chain is stronger than the oem 530 chain
it will handle well into the litre bike class
if you go to a 520 chain you must also get a 520 front and rear sprocket
if you want to keep the stock chain for whatever reason you must stick with 530 sprockets
read this site for any questions on chains, 1000rr whatever
this guy has forgotten more about this bike than 90% on any of these boards will ever know
http://www.rogueracing.org/gearing.htm
you have to get a speedo healer and then find the percentage of how much it is off compared to a reliable measurement device like a radar gun or gps
then you go the speedo healer webpage and it will calculate the numbers you dial into the unit
its easier than it sounds
