rear brake caliper mounting bolts problem
RE: rear brake caliper mounting bolts problem
this rubber piece does 2 things really , firstly it creates a suction if you like so when brake is used and caliper moves a little the suction created pulls caliper back in alignment , it also keeps out the grit and crap from road as if it got crapped up it could start to stick and cause pads to rub on discs ............when you replace it stick a small dab of lube on it .
its easier to put back if its warmed in soapy water first .....
