quick question
Got a quick question for all you wise guys in here lol My rear brakes are acting crazy, When the brake is pressed it seems to just barely move, and when it does it seems to stick some. doesnt seem to go all the way back into the reset position. That and it seems to only give me about 20 to 30 percent of its braking ability. any help would be appreciated
RE: quick question
38 people viewed this an not a one has a clue?
RE: quick question
Without knowing anything about the bike it's tough to say, but it sounds like there's something up with the rear master cylinder or the linkage to thelever. Is there brake fluid in thereservoir? How old is the bike?
RE: quick question
its an 04 and yea there is fluid there.
RE: quick question
Well... Motorcycle brake systems are fairly simple, though not necessarily easy to service. I suppose the easiest thing to check would be the brake lever pivot point. Make sure it's clean, lubricated and not binding. If all the linkage to the master cylinder is OK, thenit's probably somethingwith the master cylinder or brake caliper and/or their pistons and seals. You could try flushing the brake fluid, butI'd be surprised of that helped on a bike that's only 3 years old.
| All times are GMT -5. The time now is 10:05 AM. |
