Pirelli super corsers
RE: Pirelli super corsers
awesome tires. I'm finishing my last track set on the street. If you plan on streeting them be very careful of the rain, and make sure you get a bit of heat in them before going nuts.
When warm, and they warm quickly, they're like superglue.
When hot, they will melt and stick like super super glue. Be warned that the tire will gum up around the edges like any other soft tire... just remember that the goo that builds up doesn't have as much grip as the rest of the tire.
I think SirJag,RICHS65 and mannyrios have mistaken the Diablo Corsa as the SuperCorsa Pro or woot mistaken the Diablo Corsa for SuperCorsa..In any case I think recker is referring to the Pirelli SuperCorsa Pro tires which is a street approve race track tires..
Diablo corsa and SuperCorsa are 2 different animals...I got the Diablo Corsa as stock tires and ride it on track before. The grip level is not that good cos the tires slide left, right, everywhere when pushed hard enuf even thou I put on 30 psi on both front and rear tires.. Not bad on road conditions thou.
SuperCorsa is the God in street approved race track tires(I'm not talking about slicks here)..Optimum grip on the track. Hardly any slide..Quick warm up time..Stick like superglue..Tip in your bike into corner better..Superior race line holding..Lasts longer than Michelins' Pilot race.. [8D] Beware if you tend to finish up the tires on road after the compund is used up..still stick better than other road tires thou but in wet conditions, not as grippy especially the sides..
Anyway..recker how much it cost you plus installation and balancing?? And is your tire Diablo or SuperCorsa??
If it the PROs then they are the bomb! Alot of peps do get these two corsas mixed up! But they are two totally different tyres and I will never go back to PP! These pros are the best I have ever used on the street! Very quick 2 warm up! Supa glue feeling! Just put bluntly they are the best street tyre by far!!
Im talking about the pros guys!! These are the mak daddy of street tyres!! It costed $700 aud to get them, but these tyres are amazing, i have never had a tyre that wanted to tip you into a corner like these!! If you can afford to do this mod do it as they are great
Yes - I was talking about the super corsa... I've got a set - in dry weather best tire I've ever ridden on... in wet, not so much. Then again if you're serious about wet weather, I've got a set in my basement that would put a smile on your face.
Pirelli Full Rain Tire 180/55/17 Rear
Pirelli Full Rain Tire 120/70/17 Front
