Only one turn signal working
Hello RR lovers, I have turn signal issues, after changing the front turn signals to flush mounts they were working fine. I then Changed the rera tail ligh to L.E.D. to also incorporate rear turn signals, however NOW the right turn signal (front and rear do not flash, the front even luminate, the right work is fine. The iing is the same and fine. T thought at first that it could be the TURNSIGNAL RELAY SWITCH,but if that was the problemthe left wouldn't flash (right)? I was told i might need a load eqaulizer. WOULD THAT SOLVE MY PROBLEM?
RE: Only one turn signal working
Do you have resistors or an aftermarket flasher installed when you put in the LED's?
did you check your fuse box on the left mid fairing?
if one its burn't it won't give you the current. |
one of the wires for the front/rear right turn signals probably came off. Look into that before you get crazy and start ripping into other stuff. It happens a lot because the front wires can get snagged when the handlebars are moved if they arent routed in a certain way.
YOOOOOOO the load equalizer worked great
| All times are GMT -5. The time now is 06:06 AM. |
