Need to do Oil Change..
RE: Need to do Oil Change..
Honda recommends changing the brake/clutch fluid every two years. You're wasting money and time by changing it now. Oh and the clutch fluid is not SUPPOSED to be black. Mine was black when I first purchased mine so I flushed it out with fresh DOT 4 brake fluid and it has been a nice amber brown color for the last 13,000 miles now. Typically when brake fluid discolors like that it indicates moisture has seeped into the fluid and the nature of brake fluid is that itmixes with the moisture instead of separating like oil, causing it to discolor.
ORIGINAL: Demon RR
i run ams oil. and always run ams oil, and in all my previous bikes.
oil chance + new filter, then 3000 miles later ichange the filter. 3000 more miles and a fresh oil change and new filter.
ORIGINAL: baxsom
wierd, i read that it turns black because of the rubber clutch line.
ORIGINAL: zerochickenstrips
... Oh and the clutch fluid is not SUPPOSED to be black.
