HELP HELP HELP
Old May 5, 2008 | 08:16 AM
blkhwkcc's Avatar
Default HELP HELP HELP
Ok I feel like a complete idiot but i need some help.
Cowl cover n back is stuck on. The key will not disengage lock. (cable broke or something)
Removed the seat and tried lower whole mechanism but of course the cable still holds it up there.. I cant get the rear fairing off of course just the front two bolts.
Any ideas...
Thanks
Matt
Old May 5, 2008 | 03:26 PM
MgA_ODEN's Avatar
Default RE: HELP HELP HELP
Probably just stuck , try hitting down on the cowl when you use the key.
Old May 5, 2008 | 03:28 PM
Onarom's Avatar
That sucks. I guess I would remove the front seat and see if I could get to the cable from there. Otherwise, check from the underside around the exhaust.
Good luck Matt!
Old May 7, 2008 | 12:02 AM
chen.bryant's Avatar
ya i would try pushing down the back seat firmly while turning the key. when i put a lot of things in mine gets stuck too.
Old May 7, 2008 | 01:26 AM
RojerLockless's Avatar
happens every so often on my F4i, just take off your undertail
