-   CBR 1000RR (https://cbrforum.com/forum/cbr-1000rr-13/)
-   -   Heat Shield (https://cbrforum.com/forum/cbr-1000rr-13/heat-shield-38737/)
Ueafa May 10, 2007 04:41 PM
Heat Shield
Will anything be affected if I remove the heat shield on my bike? I see a lot pictures with them off, and must say it looks a lot cleaner, so was curious to know if there was a difference. Will my right leg get hotter than the left?
NC CBR1K May 10, 2007 04:43 PM
RE: Heat Shield
i have taken all of my heat sheild off and have not had any problems at all and your right leg wont get any hotter
Ueafa May 10, 2007 04:46 PM
RE: Heat Shield
Alright, thanks for the quick reply, taking it off now...
ASAP May 10, 2007 05:53 PM
RE: Heat Shield
what is the heat shield?
freakenfast May 10, 2007 07:12 PM
RE: Heat Shield
Do not remove the one under the seat with the stock exhaust, it will melt you plastic it did mine
NC CBR1K May 10, 2007 07:43 PM
RE: Heat Shield
that might be true, i dont have stock exhaust so i dont know
vspriderz May 11, 2007 12:26 AM
RE: Heat Shield
If you have a carbon fiberexhaust, then you should be fine without the heat shield under the seat. I took off the heat shield that sits right next to my right leg and it's slightly hotter but, not enough to really bother you.
Onarom May 11, 2007 10:57 AM
RE: Heat Shield
1 Attachment(s)
ORIGINAL: ASAP
Attachment 82676
The item on the left of this picture is the heat sheild. It goes on top of the exhaust and keeps the heat from melting your plastics.
Onarom May 11, 2007 10:58 AM
RE: Heat Shield
My Scorpion Exhaust came with an adheasive heat sheild similar to a thick duct tape. I just cut it to the right size and stuck it under the tail of the bike.
Daca May 11, 2007 11:21 AM
RE: Heat Shield
Lovely Scorpion there!
