Heat Shield
Will anything be affected if I remove the heat shield on my bike? I see a lot pictures with them off, and must say it looks a lot cleaner, so was curious to know if there was a difference. Will my right leg get hotter than the left?
If you have a carbon fiberexhaust, then you should be fine without the heat shield under the seat. I took off the heat shield that sits right next to my right leg and it's slightly hotter but, not enough to really bother you.
