GOOD no cut frame slides ??061KRR
Old 09-18-2006, 08:58 PM
FATHEADS1KRR's Avatar
Default GOOD no cut frame slides ??061KRR
Any advise on "no-cut" frame slides for a 06 1000 RR ?? Have seen several posts about one brand that bends into a water housing, and don't want that, but wondring if there were any good alternatives ?? Tried to search the forum w/no luck. Wouldn't really mind the cutting so much, but the bolt is so close to the edge of the fairing, it seems a shame.
Old 09-19-2006, 02:04 AM
Default RE: GOOD no cut frame slides ??061KRR
I installed the "Shogun" brand no cuts. Easy install, about 15 minutes for all six (bars and swing arm also)
Old 09-19-2006, 02:24 AM
I have the Shogun no-cut frame slide the work great for me.
Old 09-19-2006, 06:06 AM
i have tested the Shoguns twice ... once on each side and they've worked very well for me
you could also look @ Motovation and LightTech though
Old 09-19-2006, 12:00 PM
Arn't those the ones i've been hearing about bending into the water housing, or w/ever its called, on the left side of the bike ? The motovation site says they don't have the 06 model available yet, only 04-05. Was gonna try n call to see if it just hadn't been updated, but no # available on the site.
Old 09-19-2006, 02:46 PM
Looks as though the Motovation no-cut sliders are available for the 06 1KRR.
http://www.motovationusa.com/mvstore...?idproduct=184
They say that the sliders aren't available until the middle of May, but I'm thinking that May has come and gone already...
Hope that helps.
Old 09-19-2006, 03:06 PM
Thanks, was May of 06, and i did order em, just to find out they were out of stock !! Said they should have some next week, so no big tragedy. Just have to keep rubber down till they show up !! And after, hopefully !!
Old 09-19-2006, 11:42 PM
the shoguns are the ones that are bending the water housing
check out this site and scroll down the left side until you see the link for shogun sliders
http://www.rogueracing.org/gearing.htm
Old 09-19-2006, 11:56 PM
i've got lightech. if i didn't have them i'd go with motovation.
Old 09-20-2006, 11:46 AM
I had seen that before. Not sure what the point is if your takin a chance on damaging the engine ?? Was gonna go w/cut sliders, but the motovations look like a really nice design. Lil pricey, but way cheaper than plastics. Thanks for the info tho !
Quick Reply: GOOD no cut frame slides ??061KRR
