Charging problem
I have a 2005 1000rr. I have replaced the stator, rectifier and i have a new battery. After riding for a while, i turn off the bike and it wont start, the battery loses voltage and cant crank the engine,please help!!!!!!
Originally Posted by mjimenez1
(Post 864296)
there was a TSB/recall/warranty extension of some sort...
http://www.1000rr.net/forums/showthr...=stator+recall (Sorry for the link but it has good info) |
i have a 08 with the same problem how do you know wich to replace?
Originally Posted by tcspits06
(Post 880739)
If the 08 is still under warranty then I would take it to the dealer. It prolly wont cost you anything. Dont have some joe shmoe try & fix it if its is under warranty. They might mess something up & cause it not to be a warrantable repair.
For the 05 you need to check the stator output & check to see if it has grounded. What kind of volts are you getting at the battery? As asked before was everything replacedat once? You could have replaced something & it not fixed it & the battery is now bad. Did you make sure to install dowel pinsin the case & that one didnt get stuck on the flywheel? I have seen it before is why I'm asking. What volts are you getting at the battery? Check stator output. (AC volts) |
| All times are GMT -5. The time now is 10:23 AM. |
