Cbr1000 won't start
Hi folk i just buy a cbr1000rr 2008 and Now i have an issue i won't start
The fuel pump do not prime when i put key on I Check Main fuse 30a Sub fuse 20a Sub fuse bank angle Engine stop switch Ignition switch Duel pump relay Engine stop relay Bank angle I swap the ecm/ecu I open the Half of the wiring harness Shake and squeeze de wiring harness My next guess is to change all the wiring harness Somebody have similar problem or the solution or another guess to try ?? if is it cry i try too lolll |
