cbr 1000rr 2012 starting issues - engine clanking on cold start
Old 05-24-2018, 02:08 PM
paullyFIRE's Avatar
Default cbr 1000rr 2012 starting issues - engine clanking on cold start
Hey guys,
Firstly, awesome community.
I've lurked around numerous times looking for issues when servicing the bike my bike, so thanks for that!
Hopefully looking for some pointers before I go ahead start troubleshooting this issue this weekend, hopefully saving some time.
Here is a short clip of the (really) loud clanking sounds when starting the bike.
They happen repeatedly on cold start, unless the engine is lucky enough to crank over and start.
As the bike heats up, the issues increasingly go away when turning off and starting again, and when at operating temp, it starts instantly once the ignition is engaged.
The bike's battery is fully charged and relatively new (5 months) - haven't tested the solenoid or starter motor yet.
Any insight or experience will be greatly appreciated.
Huge thanks,
Paul
Old 05-25-2018, 02:39 AM
CaBaRet's Avatar
Hi any fault codes , if not go to your Workshop Manual page 6-6 and start from there
Old 05-25-2018, 05:12 AM
paullyFIRE's Avatar
Hey Cabaret,
Thanks for your reply.
No fault codes whatsoever - downloading the manual as I type this.
Thanks again.
Old 05-25-2018, 05:37 AM
CaBaRet's Avatar
Give a shout up if you've covered everything ,sure we can help
Old 05-25-2018, 06:03 AM
CaBaRet's Avatar
Here something you could do before anything else, get it up to warm first then switch off
https://www.1000rr.co.uk/threads/how...on-2012.11364/
The following users liked this post:
larry4201000rr (12-20-2023)
Old 05-28-2018, 02:29 AM
paullyFIRE's Avatar
Hey Cabaret,
Thanks very much for your help, much appreciated.
My father and I fixed it yesterday, so I wanted to come back and leave a reference for anyone else that has the issue.
The clanking loud clanking was coming from the engine body right side - engine wasn't cranking over though, so it had to be between the starter and the body.
We hooked up the starter directly to a battery, and it ran without any issue - so the starter circuit/starter wasn't the issue.
Our next bet was the starter clutch.
So we opened the crank case and removed the starter clutch assembly.
We removed the needle bearing from the starter driven gear.
Removed the snap ring on the one-way clutch get it out and inspect it.
And then after some troubleshooting we found the issue - 3 of the one-way clutch rollers were in the wrong direction.
Each of the rollers has a vertical line to mark it's direction, and 3 were out of sync with the others.
We took off the spring from the one-way clutch and corrected the direction of the 3 rollers.
Remounted the assembly, closed up the crankcase, and it started instantly without issue.
Mind blown.
For manual reference:
  • A diagram of the starter clutch assembly (showing the one-way clutch too) can be found on page 10-29
  • Starter clutch removal procedure starting page 10-6
Thanks again for the help.
Cheers,
Paul
Old 05-28-2018, 02:34 AM
CaBaRet's Avatar
Excellent work Paul , and thanks for the conclusion, I'm sure this could help someone in the future
Volvi
04-07-2015 08:25 AM
meeson01
10-04-2008 06:04 PM
CBR_SLIM_T
09-19-2008 04:00 PM
aadoublea
08-18-2008 10:16 PM
Quick Reply: cbr 1000rr 2012 starting issues - engine clanking on cold start
